Tire pressure - should I really use 26 psi?
24K views 12 replies 12 participants last post by  2001frontiersc
#1 ·
New to my 2000 Crew Cab 2WD. The door sticker says 26 psi all-around. That seems low. Those that have put a lot on miles on them, do you run 26 or higher?
Thanks,
Mike
#3 ·
Thanks,
Mike
I have a 99 fronty 2wd, and I ran 26psi on my previous set of tires--Traction T/A's and the front set wore out on the inner and outer sides.
The Tire shop checked the alignment and it was fine. Turns out it was under inflated. The shop suggested 32psi and there has been no abnormal wear--inner or outer sides--in over 25k.
I now run 32psi all around. The ride is a little rough, but I get better gas mileage and the tires will wear evenly.
#5 ·
I run 33 psi on all my vehciles. I think 26 would be to low and cost you in gas milage. When winter hit and tire pressure went down due to the cold, the tire pressure light came down, and it was at about 27 PSI. Maybe 26 PSI for off roading, but for regualr highway, between 32 and 35
#6 ·
I run a two or three PSI less than the MAX PSI shown on the sidewall on most of my vehicles (as long as I don't see any unusual wear). On my Frontier, I've been running right at the MAX for these tires (35psi); I ran about 42 PSI on the previous tires which were MAX'd at 44.
I guess the ride is more harsh, but I think it's better for the tire and better for MPG.
My $0.02
