Hi - new to this forum. Sorry to ask a question if answered elsewhere. I was not able to find help in the Murano section specific to my issue. Thanks in advance to any answers.
Here are how things started. A few days ago, I was a good neighbor and gave a jump to someone stranded. Shortly after the jump, I started having issues. It started when my car would not start. At first, I thought it was a dead battery. After a good neighbor helped me, I noticed that my positive terminal connector was loose. I saw sparks as I moved the connector on the terminal. The connector was tightened, but it kept sparking. (side note a few days later, after the jump, I purchased a lead sleeve at auto store and this solved my loose connection. I also cleaned the corrosion buildup)
On the display of my car, the VDC, SLIP and ABS light is on. These are the diagnostic steps I have performed.
1) Checked for code. NO CODE
2) Checked brake light fuses and ABS fuses. OK
3) Disconnected the battery. Heard if you allow the electrical system to discharge this might help clear false alerts. (I believe this is a myth and I tried it) Reconnected the battery positive first, then negative. All 3 are still lit up.
That's as far as I can proceed. My gut is telling me there was a surge that occurred because of the battery terminal post was loose.
I would be grateful if someone would provide me any additional diagnostic steps I can take. I understand that there may be wheel hub sensors and the main ABS unit that needs further testing - which will require me to jack up my car and pull the wheels. I did visually inspect the ABS sensor cables and did not notice anything of concern. But noticed a crack in my CV Joint. It never ends.
Thanks.
Thanks.
