Hi folks. Our '08 SE w/51,000 miles has thrown BOTH P0011 (Intake Camshaft Position Timing - Over-advanced - Bank 1) and P0021 (same but Bank 2) a couple of times now in the past few months. It runs fabulously, but we have noticed on occasion a light ticking sound at low engine speed under light throttle conditions only (CVT, ~25mph, steady speed). It almost sounds like lifter tick, but letting up on the throttle or giving it more throttle makes the sound go away even if the engine speed doesn't really change noticeably. I wouldn't really expect that with a typical lifter tick (oil pressure/engine SPEED only, not load). It's not terribly consistent, except that I've never noticed it when the engine is cold.
Oil is always changed between 3000 and 4000 miles with Valvoline SynPower 5W-30 and using only OEM oil filters.
I highly doubt that BOTH camshaft position sensors are going bad simultaneously, and the light ticking sound makes me think I'm hearing the solenoid that adjusts cam advance. So, my thought is maybe that solenoid is going bad and occasionally over-advancing the intake cams.
Am I way off-base here?
I have a service manual on the way, but thought I would check with y'all and see if anyone has had a similar experience.
Thanks!
Thanks!
