Turbocharger: How does it really work....?
1 reading
13K views 102 replies 13 participants last post by  morepower2
#1 ·
The only thing a turbo will do to exhaust is make it hotter. Other than that. Nothing.
#3 ·
B@lliZtiK said:
You got that backwards. A turbo uses heat energy, so it can actually make the exhaust after it a bit cooler.
Yes, the turbo uses exhaust to power itself, but because of the increased backpressure, it makes the exhaust VERY hot. A turbo will get up to 200 C hotter than an NA. It will NOT make it cooler. My exhaust hit 850-900 C under full load. If your NA gets that hot, you are too lean.
#4 ·
Turbo will also smooth it out and act as a preliminary muffler. But it will still be very loud.
#5 · (Edited)
The exhaust in a turbo is hotter because it's under much greater pressure to begin with than an NA engine would ever be.
A turbo uses heat energy, thermal expansion in the turbine chamber, to drive the turbine blades. True, turbos have a little backpressure, but it won't add as much heat as you might think. Depends on the turbo itself, at any rate. Too much backpresure and you'll have problems like the DSMs had, with the turbine chamber inlet and wastegate area cracking. In extreme cases, you'll get problems like the RX7 TTs had, with the wastgate melting under high level boost using the stock turbo setup. If you're running 900C under full boost, you're on the edge of melting something yourself. 900C is very close to the upper limit of what any engine can handle. Maintain that for any length of time and you'll start melting pistons and valves.
#6 ·
B@lliZtiK: I think you should read about how turbos work again. They do NOT use heat energy or thermal expansion to drive the turbine blades. They are simply driven off the exhaust gas flow. Nothing more.
http://auto.howstuffworks.com/turbo.htm
#7 · (Edited)
Sorry man, but I'm right. How-Stuff-Works is a kiddie site at best. Ask anybody worth a salt on this site, such as Mike K., how a turbo really works. Exhaust gas velocity accounts for about 30% of how a turbo uses exhaust gas energy. The rest is caused by thermal expansion of exhaust gases in the turbine chamber. A turbo is essentially a heat pump.
#9 ·
EZDUZIT said:
Hes right AZ, Just light a match under it and watch it spin :rolleyes:
It's a little more involved than that. Just a little matter of physics. But hey, don't beleive me. I've asked some of the resident experts to present the facts. Dunno when they'll be in , eventually I suppose.
I'm not gonna bother arguing my point. I took an entire 4 week class on turbocharger theory and operation, so I think I should know what I'm talking about..........
#10 · (Edited)
You are supposed to be an engineering student! A turbo does not make the exhaust hotter! That would be violating the laws of thermodynamics. In fact it makes it around 300 degrees F cooler!
The turbine extracts energy from the exhaust flow. Some of the drive power is expansion and mass flow accross the turbine, The conversion of heat to drive power. Some is pulse energy due to the tuned effects and harmonics of the system. Some is even accoustic energy. Look at some of your books on turbo machines.
Turbos run a higher EGT Pre turbine all things being equal mostly due to the ideal gas law and backpressure but they are in no way making the exhaust hotter, in fact they make the exhaust cooler.
#11 ·
Dude, go look at a friggin turbo. Don't study theory. Forget theory. Theory is crap without practical and real world application.
The gases don't expand in the turbine chamber. If they did, they'd blow those tiny blades apart. Expanding gases create a positive pressure. Pressure alone doesn't spin a turbo. It's the pressure differential between the manifolds and the exhaust port that causes the turbo to spin.
Turbines spin because the air is flowing through the blades. The more air that flows, the faster the turbine spins. All the thermal expansion occurs in the COMBUSTION CHAMBER of the motor. Then, when the exhaust valves are openned, this expanded gas is forced out of the combustion chamber by the upwards moving piston. So all the gases are already expanded as far as they can be. Now they are moving out of the combustion chamber into the exhaust manifolds. But there's more air coming right behind it. And the only place it has to go is out through the turbine. So the blades in the turbine are forced to spin. Because the air in the exhaust manifolds is now slightly pressurized with relation to the air on the other side of the turbine.
btw: a heat pump is NOT a turbo. And vice versa.
heat pump:
http://home.howstuffworks.com/question49.htm
A heat pump is an air conditioner that contains a valve that lets it switch between "air conditioner" and "heater." When the valve is switched one way, the heat pump acts like an air conditioner, and when it is switched the other way it reverses the flow of Freon and acts like a heater.
I guess you might want to ask for your money back for that 4 week course. Use it to buy a book called "Maximum Boost: Designing, Testing, and Installing Turbocharger Systems" by Corky Bell. Once you start reading it, you might have a better understanding about turbochargers and how they work in vehicular applications.
#12 ·
I think you need to read about how turbos work. I suggest you read turbocharging the high speed internal combustion engine by watson and genoda.
How stuff work is a sight that explains things to a Jr high level.
#13 ·
This is why EGT gauges are tapped into the manifold before the turbine. If this wasn't the case it would not matter where you tap it into.
#14 ·
EZDUZIT said:
Whats up AZ, I know you are the almighty on these cars, but every turbo car had this same problem in the late 70's and early 80's. Buick had the hardest time of them all. The US govenment said it would help aid in burning off unused fuel. So they concidered it a emissions control device( which it was not, I agree) So to make the turbos live longer they tried to keep them extra cool as to not burn up faster.
Ohh and by the way my 84Turbo is water cooled, Oil lubricated,and air cooled. Factory?
Thats on a diesel engine! In this case turbos help burn the excess fuel reduceing HC and CO but they increse NOX, a much harder pollutant to get rid of. The government never took an official stance on this as far as I know, plese show your source of this information.
Turbos are actualy bad for emmissions, they delay cat light off and increse NOX, hence the lack of CARB approved turbo kits for LEVand ULEV cars.
#15 ·
I agree. howstuffworks.com is a great site for the basics. But it doesn't go into detail about properly sizing turbos, understanding A/R ratios, spool up times, etc. But for the basics (which is how they work), it's great. It explains completely how a turbo functions and what it's purpose is.
If you really want to understand turbos and how to properly size a turbo on both the exhaust and intake side, you get the book I mentioned by Corky Bell. It explains a lot more about them as far as properties of adequate sizing and proper cooling of intake charging as well as flow capabilities.
#16 ·
heat pump:
You are wrong and Ball is right. Read any engineering book on turbomachines. Its expansion accross the turbine that provides the great part of drive force. You are offering a highly simplified view of how a turbo works. Corkey Bell is an engineer but he is also writing in a way that laypeople can easily understand.
#17 ·
I have written and published stuff on how turbos work as well that goes into more detail than corkey bells book. In fact I have several articles on turbo sizing in several major magazines. I think I have a pretty decent working knowlege on applications of turbos and so do some of my friends who design turbos for a living.
You have to take how things work with a gain of salt, its written so a grade school or Jr high level kid can understnad and glean the basics from it. My stuff was written so a high school student that knows some algebra could understand it.
#18 ·
How and why do gases expand in the turbine?
What books have you written and what publications have you been published. I am genuinely interested in knowing how and why I'm wrong and what the truth is.
#19 ·
Read Classic Motorbooks SCC's engine and powertrain handbook, the gist of stuff is in their.
Its not expanding in the turbine like releasing heat energy, its accross the turbine and extracting heat energy this way. I suggest the before mentioned watson and genoda book specficaly for turbos or any collage engineering text on turbomachines.
You need some higher level math but not alot and they are also boring reads unless you are an engineer or a student and maybe even then. Unfortunatly their are no entertaining high level books on the subject but HP wants me to write one. Turbos for dummeys or something like that.
#20 ·
Here is my $.02 to this.
I agree that a turbo uses heat energy (exhaust gases are forced through the turbine) but could you explain in more detail why it makes the exhaust a bit cooler? Did I read you right? I know that boost (very high), IC, A/F, timing affect how much heat is produced in the exhaust gases.
Backpressure as I know it is cause by the turbo piping (Length, angle, IC design, exhaust manifold) and exhaust system (precats, cats). I like the way this is stated,
"Pressurized air is then forced into the engine. Since pressurized air has more oxygen per unit volume (PV = nRT), there is more opportunity for combustion. This additional oxygen can either accompanied by additional fuel for increased power or in some diesel applications, the advantage is in the excess oxygen which allows for cleaner and more complete burning of the fuel, resulting in reduced emissions and increased efficiency."
True but my Greddy SP make my Twin Turbo sounds stock. :)
I think you were missing his point? The exhaust gases push the turbine blades which in turn forces the compressor (cold side) to force air to compress. This compression occures in the combustion camber so that more air can fit in the same volume (more O2, bigger bang, more heat) . It's a cyclic cycle of sorts.
Of course this is my opinion which based on my experiance of reading, seeing, and working on my Z. So please don't hurt me!! :)
#21 ·
I have a degree in electrical engineering and was doing calculus in 6th grade, so I don't think it will get over my head. :thumbup: Thanks.
#22 ·
That more then answered my question thanks!
#23 ·
Thermal expansion is for Jet turbin engines!Air comes in it is mixed with fuel and ignited. Once it is ignited it expands (builds pressure layman's term) then it has to exit somewhere. It is exited through another set of fins, which inturn speeds up the intake turbin which forces more air in which makes a bigger volume explosion which does what you may ask? speeds up theintake even more.
Now the point to this is that fuel is introduced into this chamber to create thermal expansion inside a jet engine.
A TURBO is feed by? AIR
Thats right AIR, you can turbo charge any car with a compressed air tank with enough volume to feed the turbo. Heck you force out cold air and the Turbo will still spin. If you don't believe that go to the dollar store a by miniture wind-mill. Light a fire under it and see if it turns faster as you blow the hottest air you can come up with on it. I with you on this one AZ-ZBUM, Let me guess a belt driven supercharger uses the heat off the belt to turn it faster. Exhaust has to come out, a turbo utilizes the free outcoming AIR to turn a wheel. ROCKET SCIENCE!
#24 ·
read above posts.
#26 ·
you're wrong man. Go read Maximum Boost by Corky Bell. That's a turbocharging book, not the stupid howstuffworks website.
Why do you think people thermal coat turbos? To maintain the maximum amount of heat inside the turbine as possible to decrease lag.
Turbos mainly spool off THERMAL EXPANSION.
In a perfect world where there is no heat soak, turbos would be lag free because there would be no loss of heat in the system.
