Sound when turning
1 reading
1.2K views 5 replies 5 participants last post by  francisco006
#1 ·
I've noticed that when i accelerate on turns, i hear a thumping type noise from the front. It does not seem to matter the direction of the turn, and does not make the noise when accelerating in a straight line. Also, when braking, there is a noise that sounds similar, although slower. The noise does not seem to be present when accelerating lightly when turning. Any ideas?
#3 ·
sounds like u need a new cv joint, the same happened to my car. does it go like *click click click click* when u turn? or is it like a screeching noise?? if its click click , then im preety sure its the CV joint, just go by a local auto repair shop and they'll replace it for u. it tooke me like 50 bux to get mine replaced
#5 ·
It could be your motor mount is broken. The engine moving will make a clunk as your engine moves upon accelleration and when braking to a stop. If this is the problem, you may also feel a thump as you stop as the engine sets back into place.
#6 ·
could be a number of things, if it is ur axle ur best bet would be to change the cv boot now if its craked and regrease it cost is about $30 for parts if u decide to wait youd have to buy the axle for about $120 so its really up tp u.
also it could be the wheel bearing, it really depends on the noise, ud have to describe it... is it a click click sound or a clump clump ...lol im not sure if itll make sense but see if u can notice the difference.
