The other weekend my X-Trail made a horrible noise from the rear. I drove around the parking lot trying to figure out what it was. I jacked the vehicle up and took the rear tire off. I turned the wheel using the studs and the brake pads were grinding against the rotor. I had the vehicle towed to the dealership, where they told me I had to replace the rear pads and rotors.
I didn't have any warning and upon inspection of the old pads I seen the pad with the warning tab was barely warn. That is, only one pad on each side was worn out, while the other pad had a fair amount of life. The dealership in Saint John said they have had to replace four or five rear pads on the Xtrails and Altimas. I checked with my dealer in Fredericton and they are unaware of any problem.
I rotate my own tires and watch the front brake pads, as these typically wear out first. Have any of you replaced the rear pads first? I had 78 000 km when this repair was done. I know this is high mileage, but it is all highway and I use my transmission when I slow down. I have had seven nissans and this is the first one I replaced the brake pads on (normally trade at 140 000km), especially the rear pads.
I would appreciate any comments/insight on this matter..
Greg
Greg
