I'm looking to replace my 97 Hardbody XE X-Cab 2wd (4 cyl, automatic) with a 2005 Frontier (4 cyl, automatic), so I'm looking for real-world gas mileage numbers for the 2005 Frontier 2wd (Auto or 6 speed). Thanks!
For those of us with the 2.5L 4 cylinder, just confirming that 87 Octane IS the recommended... the manual seems vague, saying it can take 87 Octane, but for BEST performance/results, use 91 Octane. Most manuals just tell you what Octane to use and that's it.. Is 87 the best for this engine (that's what I'm assuming)??bob022004 said:Hey SD....you do know that it hurts your performance and gas mileage when you use a higher/lower octane than your motor is designed for? Try using just 87 and you'll see a slight improvement. I had a friend try 110 octance gas in his SRT-4 and it ran like s***. Unless your engine is tuned for the higher octane all you're doing is wasting your money.
bob022004 said:Demob05-Not sure about that one. I'd say call Nissan for clarification. But unless it specifically says premium unleaded only i'm going 87 octane and saving my money because the potential gain you might see out of getting 91-93 octane isn't worth the cost.
Yeah but intakes and exhaust systems have restrictions due to the fact that car manufacturers put resonators and baffles in EVERYTHING to reduce sound, usually aftermarket intakes and exhausts get rid of those restrictions making it louder, give a lil bit more power and lil bit better MPG.bob022004 said:it could help because it improves the airflow of the engine....if you stay out of the loud pedal. but the improvement won't be that noticable. today's newer vehicles aren't near as restricted as the emissions stuff from the 70's and 80's. Technology has allowed for less restrictive intakes and exhaust systems from the factory than before.
