Hey there,
Having a problem with my 2002 Pathfinder windows not rolling back up.
Recently, both power windows in the rear seat won't go up when pushing the rear seat window switches on the rear doors.
Both switches on the rear doors will let the windows go down fine, but won't respond to go back up.
I don't believe the window lock switch on driver's master control panel is the problem as I check that, and when unlocked it allows the front passenger window to open/close (normally that lock switch prevents the front passenger switch and rear seat from operating). I also know it's not the lock switch because the rear windows go down (just not up). However, the rear seat window buttons on the driver master control won't move the rear windows either up or down.
I pulled the door panels off in the rear seat, and rigged jumper wires directly from the batter to the power window motors, and was able to get the windows to go back up...so I know both of the motors appear to be good.
I doubt if both rear seat power window switches went out at the same time (as they still are able to lower the window..just won't go up).
If it was a bad fuse or bad wires, then the windows wouldn't be able to lower (which they do)...right ? Or is that a bad assumption ?
Since I'm only having a problem with the window going back up on the rear seats, is there possibly a relay switch that I can check, and where would it be located.
Any other ideas would be greatly appreciated.
Thanks.
Thanks.
