Alright don't know if this issue has been diagnosed in a discussion before but I have an electrical issue. I am a pretty smart guy when it comes to mechanical but electrical....ummmmm no! Ok here is what happend.... I did some work on my Pathfinder. Replaced radiator, new spark plugs, crank sensor, both cam sensors and a water pump. Well I started it and it ran beautifully for about 5 minutes or so then it starting running rough and got a code for the camshaft sensor bank 2. I went under the hood and realized the connection had come off the sensor. Tried to reconnect it but engine got to hot. Turned it off waited a few minutes then reconnected the sensor. Tried to start vehicle and it wouldn't start. The engine turned over no problem. Cranked engine a few seconds and it tried to start then went back to cranking. I tried this several times same thing. Anyway the last time I tried to start it all the electrical power just shut off. I know battery is good because it is brand new and has 12 v. I checked it with a multimeter. I only had one blown fuse and replaced it to no avail. I checked all three fuse and relay blocks with multimeter and all are getting power. The block relay on the battery blew one of the fuses and was also new. I took the old one and tryed it because it worked before. Nothing! I have no electrical power to the whole vehicle. I suspect the bcm. If someone has had this issue what was the fix? A relay, ground, ecm, bcm? Please anyone chime in with any suggestions. I just bought it and didnt even get to drive it. Thanks all
