Need some help with 4.0 motor specs
2.1K views 4 replies 4 participants last post by  BRubble
#1 ·
Aloha, guys. I'm in the process of replacing the head gaskets on a 2006 Nissan Xterra. The information that I have for the camshaft caps indicate a final torque spec of 52 in-lbs. I'm not a true Nissan guy, I seem to work more on Toyotas. The torque spec of 52 in-lbs seems too low to me (in comparison, the camshaft caps for a Toyota 3.4 is 144 in-lbs for what appear to be identical screws). Can anyone confirm these numbers?
Thanks, Raymond
#3 ·
bolt torque
Thank you for the response. That sounds more appropriate, if still a little low. I was using the Automate instructions from the Canon city library database. Kind of scary that the info on it would be wrong.
