Look at the distributor cap. If there is a wire in the middle of it, follow it to the coil. Most likely, there will be only four wires on the cap, which would mean the coil is inside of the distributor. In those cases, the tach wire is usually hooked up to the signal wire at the ECM, but get instructions from the tach's manufacturer to see what they recommend.
