ESCL issues… did I brick my car?
1 reading
4.2K views 35 replies 3 participants last post by  dubya315
#1 ·
I have an 09 Altima Hybrid, and I was getting no response from my push to start. Keys in the little hole on the left of the steering wheel do nothing. Just a yellow light on the dash of a key. Did some research, and found that my ESCL could have gone out. I tapped it with a hammer a couple times, and the car started. Eventually this didn’t work anymore, so I bought the Dorman OE replacement kit, which comes with a new unit and a programmer. I installed the part, and the ignition works with the key in the key port on the left of the steering wheel (ignition only, car won’t start) but now both keys aren’t recognized and I cannot use the programmer in unison with the keys. Is there a fix to this? Did I brick my cars computer? Do I need to call a mobile locksmith or tow to the dealer? Any info helps. Thanks.
#3 ·
#4 ·
From what it says in the "Troubleshooting Guide" off Amazon, it looks like the programmer is supposed to configure the lock for whatever car it's installed in by interrogating the car. Maybe that just doesn't work right. Nissan actually recalled all the ESCL's on the '09~'10's and replaced them with "dummy" lock emulators that don't actually lock the wheel, bulletin NTB17-018:
The recall has been concluded so that isn't an option for you, but unless there's some reason you really need to lock the wheel, you might have been better off with a $40 emulator than the Dorman lock. If it was me and it's returnable, I'd dump it and get an emulator.
#6 ·
That sounds preferable to me actually. Where could I find one of those emulators? And it looks like I would still need to reprogram my keys correct?
If the Dorman wiped out the BCM's memory, then yes, you'll need a dealer or a smithy. Like I said, the locks themselves (and lock emulators) are supposed to be plug-and-play, when we get no-starts at the dealership with bad ESCL's we just plug in a "known good" used one to get the car started and into the shop. The ESCL has no part in the I-Key system, that's strictly handled by the BCM. So it's an open question what the Dorman programmer did to your system.
#14 ·
Do you have a red key light in the cluster when the ignition is on? If you do then the smithy is wrong and the keys aren't programmed correctly. On a lot of the old stuff the RKE receiver is outside the BCM and needs to be programmed with a separate algorithm, so that may or may not mean anything. I'd have to look that up. If there's no security lamp then you have a different issue, maybe a brake pedal switch or maybe the Dorman is screwing something up. If you have any kind of code reader, it would be a good idea to at least see what codes are in the ECM (engine).
#18 ·
Battery fully charged, still no start. New brake light switch, no difference. The OBD2 scanner found no issues with any car systems. It’s weird. I feel like the Dorman programmer messed up a computer or something. I may contact their support and see what happens. I hear they’re not that helpful.
#21 ·
Like I said earlier, the RKE may be a different issue, it has a separate antenna. The I-Keys actually have three different systems inside, a "garage door" FM frequency for the RKE, a GHz frequency for the short range in-car antennas and door requests, and an RFID system that doesn't need any power and only works in the doghouse. The only thing they all have in common is that the signals all go to and through the BCM by various means. So if it starts by way of manually tripping the starter, you'll at least know the BCM isn't preventing it from running, just not telling the IPDM to spin the starter. That will pretty much be proof positive that the Dorman screwed up the BCM.
#23 ·
Ignition on and jump the smaller terminal on the starter (solenoid) to the larger one (battery). If it doesn't crank then the starter is bad. IIRC the Altima hybrid has a regular starter, I think only the later hybrids used the traction motor for starting. I'll check that and get back to you. Even with a hybrid, I'm pretty sure the ECM will start the engine when it sees it spinning, but with no ready light, it may shut down immediately on command from the VCM (hybrid controller). Either way you may need a scan from the dealer or someplace with a high-end shop scanner, because after the BCM permits startup, the VCM is ultimately responsible for "ready" status and deciding when to run the engine. Most ordinary scanners won't read either one of those modules.
#24 ·
Well, crap, scratch that. Been a long time since I worked on one of those drivetrains. The MG1 hybrid motor is used as the starter, so there's no way to jump it. I don't think you'll be able to sort this out without a scanner which can read all the systems, including the VCM. Find out why there's no Ready light and you'll get to the bottom of it. Hopefully it isn't a flat HV battery, that's a big can of worms.
#26 ·
I doubt the BCM is "fried" or the smithy's tools wouldn't be able to talk to it. But could the Dorman have altered the configuration? Sure.
Is the Dorman still in there? The first thing you need to do is assume it's directly interfering with the car. Remove it and replace it with an emulator and see if the car wakes up. If not, replace it with a junkyard ESCL and see if it wakes up. If that still doesn't do it, you're going to need a whole car scan with either a Nissan Consult3+ or a high-end shop scanner like a Snap-On Solus which can read from all the systems on the car. Without knowing what systems the Dorman may have affected, you won't get answers any other way.
