differances between de and det sr20
2.8K views 8 replies 6 participants last post by  mav1178
#1 ·
i know someone sent me a link in one of my old posts to the differances between de and det. i can get a g20 sr20de REAL cheap but i need to know some of the diffs first. is it distrobuter or dis. comp ratio. can i use ka computer on it. can i have ka comp reprogrammed to work. can i use sr20det harness and computer on it. i know im gonna have to get a trans for it. im not running ac or pwr steer so im not worried about that. if there is anything else diff please do tell. thx guyz
#2 ·
no replys huh? ok i found de has distrobuter and i found out comp ratio. small potatos. i need to know if the ka ecu can run the sr motor. most of all i need to know if i can use ka harness on the motor. PLEASE HELP!
#3 ·
The differences are mainly compression ration, oil coolers, and a few other differences. You mentioned getting a G20 motor but this is in the S13 forum, the G20 motor is a FWD motor and will not work in the s13 chassis. As far as the Ka ECU, I've heard of people using them on an sr20det in an s13, but I'm more than sure it needs to be retuned. Personally I would use the sr20 ecu as that is what it is intended for.
#6 ·
FFgeon said:
i was going to use sr20de rear wheel drive motor from japan
well, for starters. the RWD SR20DE does not come out of the G20 (also known as the Primera in Japan).
the RWD Sr20DE that you're referring to would come out of the Silvia Js and Qs. the Silvia Ks are carry the SR20DET.
there aren't a whole lot of differences. you're biggest worry should be that the CR in the SR20DEs is higher than that of the SR20DETs. so, that would mean you would have to basically rebuild the block (or engine, if you want) to lower the CR, and then turbo it. whereas, you could just get the SR20DET for about the same price as rebuilding the SR20DE.
but here's another thing that you probably overlooked. the SR20DE from the Silvia Js and Qs WERE NOT made in the states. so, that would mean that you would have to have one shipped in from Japan, Australia, etc. rebuild the block or engine to lower the CR, and then turbo it. if you like to throw away money, go with that route. ;)
#7 ·
now, now edwin, you disappoint me..
Here are the differences between the DET and the DE:
The DET has oil squirter piston coolers
The DET has a bigger oil pump.
The DET has a different front pulley.
The DET has lower compression pistons (8.3:1 vs 9.5:1).
The DET has bigger injectors.
The DET has direct ignition.
The DET has a variable intake cam, runs retarded at idle, advanced mid range and retarded top end.
The DET has mechanical shim in bucket type lifters with a slightly bigger in duration exhaust cam.
Stop trying to reinvent the wheel. I'm sure I'll say this a million times before I stop helping people out, but there is a reason why the SR20DET is so popular. It's a fairly simple and straightforward procedure. Nobody buys DE's and turbos them, nobody converts the FWD SR20's to RWD for the 240's, only a small percentage of people turbo their KA's. If you want to be different so bad, put a VG30 or RB2x series engine in there.
