Great forum by the way.I`ve learned a lot about my car here
1.When the car is cold,it`s fine to start.But whwn I start to drive,and change gear,the rpm wont go down!If I change gear and have 2500 rpm,and push in the clutch,the rpm is still on 2500 rpm. And when the car is warm also,the rpm is just over 1000rpm when I press inn the clutch.But if I stop the car,it`s normal(just under 1000rpm)
2.My car went very bad,no more acceleration after 2-2500rpm.But I changed the fuel filter,and now it`s OK
But it feels like the car loose power after 3500rpm.Is this normal?Is it like max torque on 3500?
3.My parking sensor stopped working,is there a fuse etc. I can check? There are even no beep when I take it in reverse.
