Long story short = I Bought a 2011 Nissan quest and found a dealership CVT trans for 1k new. I removed the old and installed the new. All fluids are fine, everything is connected the way it should be. It drove fine for the first few days and then began to have other problems that do NOT relate to the CVT. Firstly, there was an abrupt jolt/hesitation/jerk going 35+ MPH when you would let your foot off the gas and back on it. Later, it threw a MAF code, which I replaced, cleared codes, cleaned/inspected wires, and still had the same issue after. That MAF code now became a permanent code. After the permanent code came on, it gave me a Crank Position Sensor code. I replaced the CPS, the old one was worn out and looked slanted from the wear/heat. I drove it, and again the code came back. However, now when going WOT the RPM maxes out and bounces at 4k-5k. Jerking occasionally happens. I have also replaced the air filter. Inspected new CPS and it is not damaged, which is a relief.
So what could be wrong? Could bad sparkplugs or coils be causing the MAF to mess up and throw a CPS code? Could dirty injectors be a possibility? Did my MAF come damaged? Should my next move be to connect both battery cables and leave them connected to reset everything?
