85 Z31 M/T engine problem. - Nissan Forum
Z31 300ZX(T) 1984-1989 Zs - Engine and Chassis Discussion
post #1 of 1 Old Apr 14th, 2019, 05:29 PM Thread Starter
I have an 85 Z31 and for a while now I have been unsuccessful in finding why my car won't run properly. For starters, the ECU is throwing a code 23 (idle switch). The car will idle up as normal but try to die intermittently as it idles dropping in rpm. Any pressing on the throttle kills the engine almost immediately. Strong smell of fuel in the oil as well as the exaust. No smoke or anything else is noticeable. In all my attempts to find the problem I have removed the intake, checked all the fuel injectors for leaks, replaced the FPR along with the fuel and vacuum lines. Installed a new mass air flow and all the piping leading up to the TPS has been cleaned. Tested the plugs and resistance to all these parts as well. No change so I then went to the plugs wires and ignition coil. All new tested and greased. With the plenum off I replaced all vacuum lines that I could locate (including the ones that send coolant through the throttle body) this had no effect. I then replaced the distributor cap and rotor because there was significant arch damage. Still no change. Lastly, I changed the oil because after all the misfired attempts to get the engine running right the oil was smelly of gas. Does anyone have any other suggestions that I might look into? Any input is appreciated. (On a side note, if it is an electrical part, harness or connector. It has been tested although I'm sure skimmed over quite a few) thanks again!
Drewz31 is offline
  Nissan Forum > Nissan Z > Z31 300ZX(T)
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Linear Mode Linear Mode
'85 Z31 ECU trouble code 23 Lynx88 Z31 300ZX(T) 8 Aug 18th, 2014 04:12 PM
'85 Z31 Turbo Timer Install silfortytypex Z31 300ZX(T) 1 Sep 3rd, 2005 08:37 PM
85-85 maxima 86_NISSAN_MAXIMA General Maxima Discussion 7 Mar 23rd, 2004 11:39 AM
Z31 '85 NA 300ZX clutch removal/diagnose? De La Rocha Z31 300ZX(T) 1 Jul 9th, 2003 08:28 PM
85 Pulsar Front end on a B11 85 Sentra SuperHatch B11/B12/KN13 82-90 chassis 15 May 28th, 2003 11:59 PM
You may post new threads
You may post replies
BB code is On
