1 - 8 of 8 Posts
ex-Super *********
Where do you turbo guys pick up the signal for your wastegates? Compressor outlet, after IC(before TB), after TB? I know a little bit on the subject(some pros and cons of the locations), whats your take?
Icy Hot Stunta
The bst place for the snappyest response is as far away form the turbo as posible, which means the manifold plenum.
Mike
ex-Super *********
Mike, If I go to the plenum will I get boost-spike induced heat? If so, will it be very much heat or would it be nothing to worry about?
Hey Mike, what exactly do you mean by snappiest response? Right now, I have both my wastegate and boost gauge from before the throttle body, after the IC. According to the gauge, the boost is spiking pretty high (10 psi) in 1st gear and will spike up to 8-9 in 2nd, etc. This is running a DET t25 with the stock wastegate and actuator. I was thinking that if I got the wastegate signal closer to the turbo, it would catch the pressure build up faster and keep it from spiking. It's actually about as far as you can get without being from the manifold plenum but I was going to move some of the vacuum lines around.... thanks for the tips!
Khiem
Icy Hot Stunta
No don't worry, I take the signal by teeing into the fuel pressure regulator line.
Mike
Icy Hot Stunta
Khiem
You will notice a more laggy soggy feel if you locate it in your compressor housing.
Mike
ex-Super *********
Mike, even though you said not to worry about it I am curious about these things. Could you give me a precentage of boost spike that one would see with the signal from the plenum as compared to the compressor housing. I know there are probly alot of variables between different setups(IC,pipes, ect), but when the gears in my head start turning on something, even a monkey wrench wont stop them.(unless you hit my head with it)
Icy Hot Stunta
The boost would not spike any more than would be worth doing anything about
1 - 8 of 8 Posts
