You're most welcome. It's rare on Rogues to find pinched or disconnected hoses, clogs are almost always in the bottom fittings. Sometimes the clog will clear in a gush of water as soon as you remove the nub, but the Murano in the pics was the same situation as yours and had a hard pill of debris and pine sap built up behind the nub on the passenger side. If that happens, use a slender screwdriver to break up the debris. If you have compressed air, put a shop rag over the upper ingress with the roof open and gently blow any remaining debris out the top. Without air, snake some weed-eater line about 6" up the tube to make sure any debris is loose, then pour water down the troughs until it runs clear and free.
Note that you can't check the rear drains on a Rogue with the car level, to check the rears you must park on a slight uphill. Water should emerge just behind each rear wheel. The drain on the side with the jack is easy to reach by pulling the jack, the other side requires loosening and pulling back the rear portion of the cargo room trim. The rear fittings have the same nubs as the front drains, but reaching them similarly from the outside is difficult. Instead, force a short phillips screwdriver through the fitting from the inside until you feel the nub break.
