Ok here goes, a COMPLETE write up on removing the aircon from a b13 ga16de
could be useful on an sr20 as well
Ok, first off,
remove the freon gas from pipes (with proper equipment of course
remove the pipes from the canister on by the a/c radiator
remove the same two pipes from the fire wall, you will need two big spanners to do this.
remove lines that go to the compressor from the condensor (radiator thing)
remove condensor.
jack up the car, and with a 14mm socket, remove the bolts that hold on the compressor, two of them.
now you should be able to remove the bracket and all, there is another component attached altinator/generator.
if you want to, cut the bracket in half, and drill several holes (just be careful where you drill them) and repllace bracket and altinator.
you will need a new belt now, if some one can add what this part number is would be great.
ok, now inside the car
remove the glove box, and side panels.
there should be a brace that goes along in front of the black boxes behind the glove box.
remove that
now, the middle box, where the a/c pipes went in, will be removed, takes about 4 bolts.
once you have it out, you can take it apart, and remove the cooling unit radiator thing inside that.
put box back together, block off the holes on the box, and replce back.
put bar back inplace, and glovebox
that should be all that needs to be done, its a basic write up but this is basic wording, and will need some thinkning involved.
ask away if you got any questions.
Ok, first off,
remove condensor.
remove that
