I have a 1996 Altima that refuses to start while the engine is hot. It starts fine in the morning and can be driven for miles without issue. However, when I turn it off at the gas station, it won't start again until the engine has cooled down. If I wait for ten minutes or so, it will crank and almost start, but die.
The distributer has been replaced, but the problem persists. The temperature gauge does not indicate overheating. The ECU reader returns no error codes. This seems like some sort of sensor issue, but I'm not a mechanic. What is causing this problem?
