1 - 11 of 11 Posts
2018 Nissan Pathfinder SL
does the motor run ? check the linkage there are plastic clips that go U S
200SX SE-R
If the motor is running check the connections of the wipers to the motor and eachother. Mine were broken because linkage between the two broke and they were no longer connected.
I had this problem, the wipers wouldn't park or work sometimes. It turned out to be the intermittent wiper relay on the passengers side, specifically where the relay is soldered onto the circuit board. The solder had cracked, so resoldering them did the trick.
I was tracing the fault at dusk and had the electronics out of the case, I could see it arc in the dim light. The joint looked OK but was not.
could you give me some more info please.
i have the same problem, no intermittent wipers and it wont park itself.
i have not been able to fix this problem
On the passengers side of the vehicle, behind the glove box, attached to the frame up high, where you really can't get to it easily is the intermittent control relay.
If you remove it and open it up (just pry back the tabs and pull the board out)
you will see a black rectangular micro relay soldered at 5 points to the circuit board, in clusters of 2 at one end and 3 at the other. Take a soldering iron and some rosin core solder and resolder the cluster of 2 and the center one in the cluster of 3. Do not be fooled into ignoring this because the crack in the solder is nearly invisible, just resolder and reinstall.
1 - 11 of 11 Posts
