and even if you have an airbag, put on a b13 steering wheel with no airbag or aftermarket one...wieght reductionbarnoun said:B14 steering wheels have an airbag. Does your b13 steering wheel have one? If not, getting a B14 wheel seems like a waste of money.
even more weight reduction when your dead...lolXtremE said:and even if you have an airbag, put on a b13 steering wheel with no airbag or aftermarket one...wieght reduction
I'm 98% certain the wheel will bolt up, but the cruise will not hook up the same because of the airbag. The airbag equipped wheels have a spiral cable for the cruise connection and the non-airbag cars have 3 connections on the horn ring on the back of the steering wheel.johnand said:Just as the subject says. I want to make sure the cruise buttons will work as well?
That's an SE-R wheel. All SE-Rs had 4 spoke wheels.barnoun said:Isn't that the steering wheel all b13s with airbags have? It's on all the b13s I've seen in the US... In non airbag versions, the wheel has like an oval center section with only two spokes, right SergioCR?
....similar i guess... mine says it has SRS airbbag but seems to be that the previous owner or maybe when the car entered the country some smartguy stole it and put the normal two spokes one. Also, the new one looks all black, mine is brown-like.barnoun said:Isn't that the steering wheel all b13s with airbags have? It's on all the b13s I've seen in the US... In non airbag versions, the wheel has like an oval center section with only two spokes, right SergioCR?
