1 - 10 of 10 Posts
Will 17" x 7" rims fit my 1998 200sx se? I think so, but id like to know before i buy? Even with coil overs? How far can i drop it with the rims on?
Banned
I have 18x7's on my 97 200 sx se, and have NO RUB...
my tires are 215/35/18
as for dropping it... you can go A LOT... i have the 18"s and could still drop it 4"
I have had 19's on mine w 215-35-19 tires.
I have 17 * 7's on mine and no rub. I also have a 2" drop.
i got 205/40/17's with coilovers(2.5 inch drop) and i have no rub. the only problem i have is bad camber wear. now i got my stock alloys in the front. now i got to get an alignment and 2 new tires
Drive fast and fly low....
so, if i do intend to drop my car with the coilovers that i am getting, i should also invest in a camber adjustment kit, like from stillen?
I have Ground Control coilovers on my car & I got camber like a bitch. You should at least get a wheel alignment once you get the coilovers on. I'm not getting a camber adj. kit... all you'll really need is some new struts. :D
7.5" is the most you can go
1 - 10 of 10 Posts
