So I bought my self some auxiliary lights to act as high beam. I have connect the relay and it works, but I cant find a place to connect the wire that will activate the relay. I have the repair manual and I have not found the cars light relay to connect to. Where would you connect the wire? have tried connecting it through the main bulb and it was very unreliable. So where would you connect the wire that activates the relay? I want the lights to activate by the high beam light stock.
Thanks for advice!
Sup Mod keeping the peace
If you just want to control your aux lights separately, just run a fused wire to the positive battery connector.
If you want to control your aux lights through the combination switch (lighting switch), then here's two diagrams of the lighting system where you can tap into. These diagrams were taken from the FSM for a 2006 x-trail:
6473
6474
