Hello all,
I am trying to replace the 3 rusty and bent steel wheels and one spare that are on my 86 Pulsar, I am trying to go cheap and find some factory aluminum wheels, I don't care what they are from, I have found many wheels with the correct 4 X 4.5 lug pattern in 14" and 15" at one of my local junkyards, I just can not find any with the correct offset, they are all around 40-50 MM positive which is too wide/deep and will rub on the lower control arm and shock.
I thought about wheel spacers but a quality set of 1 1/2" spacers with studs will run about $200 and I can get brand new wheels for that.
Anywho, has anyone had any experience with fitting any other factory aluminum wheels on the Pulsar?
Thanks for any input
Ritch
· t3h r0XX0r!!
ritchz said:
Hello all,
Ritch
'86, that's an N12, right? if so, the wheels from a 78 dodge challenger (imported for chrysler) fit, but good luck finding any.
not positive, but i think 280Z wheels fit...
there were some early (like 83 or something) maxima wheels that fit, too, i think (same thing as a z-car, essentially)
the trick is, the wheels need a RWD offset... i have no idea why nissan made 'em that way.
