for 2wd 2.4L automatic use any of the following:
Castrol Dexron VI ATF
Dexron VI replaces Dexron III in GM products
Castrol Domestic Multi Vehicle ATF (Qt)
Castrol Domestic Multi Vehicle ATF (Gallon)
Castrol Import Multi Vehicle ATF
Castrol High Mileage ATF
Maxlife ATF Dex/Merc
Coastal Multi-Purpose Dex/Merc ATF (Qt)
Coastal Multi-Purpose Dex/Merc ATF (Gallon)
Coastal Multi-Vehicle Synthetic Blend Mercon V ATF
Mercon V replaces Mercon for Ford vehicles
Mobil 1 Synthetic ATF Mercon V
Your owners manual specifies Nissan Matic D. It also states that Dexron III/Mercon may also be used. I would not use any of the higher numbered Dexron or Mercon fluids, e.g. Mercon V, Dexron VI, without Nissan recommendation. While automatic transmission fluids may be identified as interchangable by their manufacturers they may differ in properties (lubricity, detergency) that cause a vehicle manufacturer to specify a certain type or brand.
Steve
