1 - 14 of 14 Posts
ive been doing some research, i want to go with ngk v-power plugs and ngk wire{those blue ones} is there anyone had them on? how do they work? or please some detailly advise whichone is good on the car . btw,my car is all stock and runs good. thank you very much!!!
also my car is all stock, if i just put on these IX-Iridium plugs, and ngk wire , would the spark be to strong, cuz some body told me he heard a stock car with g-power got a engine shaking issue when the car was driven on the hill and hot weather. i dont know i should beilive it or not, how about you car do you think stronger spark will effect the car like that in a negative way?
ok, want to know whats the best u can get? Go for Denso Iridium Spark plugs. why?
Construction of NGK and Denso plugs is similar for the most part, the big difference being Denso's use of a 0.4mm Iridium tipped centre electrode - claimed to be the world's smallest production centre electrode, where NGK's IX centre electrode is 0.6mm. As with NGK Iridium, and indeed most other spark plugs, the narrower the centre electrode is, the lower the potential difference (voltage) that is required to jump the gap between centre and ground electrodes.
You can get more info here Iridium spark plugs by NGK and Denso
as for the wires yeh go for NGK, just whatever u do DONT buy the Nology Hot wires. here we go....
Electrical devices, including SPARK PLUGS, use only the electrical energy necessary to perform the function for which such devices are designed. IGNITION WIRES are nothing other than conductors, and whereas an ignition wire's inefficient or failing conductor or insulating jacket (particularly a jacket inside grounded metal shielding) can reduce the flow of electricity to the spark plug, an ignition wire that allegedly generates an "increase" in spark energy will have no effect on the spark jumping across the spark plug gap, as the energy consumed at the spark plug gap won't be any more than what is needed to jump the gap (e.g. a 25 watt light bulb won't use any more energy or produce any more light if it's screwed into a socket wired to supply current to a 100,000 watt light bulb).
So in short, you will be spending good money on crap that u could spend on other better stuff that will actually make a difference. I mean its not totaly crap, it does help, just dont expect some power gain, as ull get non.
err no. im saying cables are cables. and unless ur trying to transmit digital signals throught it, u shouldnt worry about how good they are as long as they move the current they need to move. what im saying is that the only real difference u get by putting cables and sparks on ur car is maybe a little better milage and a more even spark at med and high revs, probably a better smother idle but thats all. Dont expect ANY power gains.
i would better take does 300 bucks and buy a filter and exhaust. you will LOVE the sound and u will actually feel some powergain, specially if u live at sea level. First thing i did to my b14 was that, cold air intake filter. and i dont regret it. Right now ive spent about 3200 dollars on it, suspension and engine and i havent bothered changing cables or sparks, i just feel im wasting my money.
This is a good point. There is no HP gains from racing plugs and wires. Just get a set of Auto lites and plugs from Advance and save your money. HP gains from plugs will get you as much as a CAI (zero!) Autolites will get you just has good of gas mileage as any plug out there.
Jason
1 - 14 of 14 Posts
