J
Jimmymus
·Guest
I'm hoping I don't need premium gas like the Maxima. I'm trying to go cheap cheap cheap here, and the Sentra seems good.
The stock timing on the 1.6 engine is set at 10 +/- 2. 15 is probably the highest you should go and yes you MUST use premium.how much is the b14 timing degrees set to? 8 degrees, and if you advance it is 15 the best to go plus filling up with premium fuel? thanks
That is because my se-r has the sr20de engine while your car has the ga16.it says that you have it timed to 17 degrees isnt a little too much, and how much should i advance if im not sure whether its higher than 10 by 2 degrees or lower than 10 by 2 degrees? kinda confusing
It would proabably be knocking.shmuck90 said:what are the symptoms if you fill up with 87 octane and you have your timing advanced, because i was thinking what if the last person before me that had the car advanced the timing? i wouldnt know, if its detonation how would you know? lol
