1 - 20 of 50 Posts
straight up bolt on
1. Headers
2.Intake system (short ram or Cold air intake)
3.exhaust system (includes the headers to the down pipe and muffler)
4.change plugs and wires.
Im at work if i missed anything plz let him know here comes my manager good luck with your project.... keep us updated if you want also check around the forum theirs a better response then mine out their
who needs clearcoat
If you use premium gas you can get away with advancing your timing a bit. If you have deep pockets you can go for cams and an ecu reprogram. Theres also porting and polishing.
2018 Nissan Pathfinder SL
95-99 GA16DE made a manufacturer stated 115hp, about 90 bwhp on the Dyno
who needs clearcoat
If you search the on the magazine sportcompactcar they did 3 articles in which they did the basic bolt ons with a dyno chart for all of them.
Super Moderator
Did you feel the car take power or any change
Not really. It was a old a motor when i got her, she wasnt in her prime (194k) cheap and easiest mods are-
-Advance the ignition timing (requires higher octane fuel)
-WAI or CAI (intake)
-Exhaust (no bigger than 2 inch on a n/a 1.6L)
-Header (obx has them on ebay, if you get lucky enough and find it, get a hotshot)
-Jwt aluminum flywheel (pricey like close to $400 bucks i think)
Little mods like a short shifter, polyurethane motor mounts, help alot too.
As far as short shifters go, i got a B&M its great i love it, some people like the "nismo" ebay ones, some dont.
polyurethane motor mounts, they only make them for the SR20DE (fwd) they fit, i had them on my 1.6L, search my old threads, its in there. Polyurethane motor mounts cause more engine vibration, but you'll like it. It reduces engine movement to almost zero.
Then more serious mods for the 1.6 are - ( i only call them serious cause they're over $500/each )
-Jwt ecu reflash (easy to install)
-jwt cams (S1 series i think?)
-forced induction...
Its all about how much you wanna spend.
Here is my cardomain on my old 1.6 - http://www.cardomain.com/ride/2554540
1 - 20 of 50 Posts
