How do I replace the water pump on a Nissan 200sx with a 1.6 engine?
i've done it like that and i have also lowered the engine and replaced the water pump from the passenger wheel well.The water pump is in a very precarious place. What I did was place a block of wood between a jack and the crank pulley, unbolted the passenger side engine mount, and lightly jacked up the engine until the water pump cleared the frame rail. It makes removal and replacement much easier... but make sure to use the wood otherwise you could damage the crank pulley or crankshaft itself. Also use some light wood, so the wood has some give in it.
my only guess is support the engine with a jack or tower and then jack up the car, after undoing the mount of course.I caught how to lift the engine but how does one lower the engine?
Thanks
