1 - 20 of 24 Posts
My '97 Sentra (150K) has started making some loud grinding type noises seeming to eminate from the front of the motor mainly on start up and in this fridgid weather here in Ohio. It won't do it right away at low RPM, but as I begin to drive, it starts. No dash lights and seems to be circulating coolant fine. As the engine warms up, the noise is not as loud, but still there. Every once in a while at a stop light or in low RPM it will stop but usually starts back up as i begin to accelerate. This weekend I plan to pull the belts and inspect each thing by spinning by hand, but want to see if anyone else has had this issue. What typically happens when a water pump or idler goes bad? Would a timing chain tensioner make this much noise? Thanks
Timing chain would make the noise from the passenger side under the valve cover. Is it coming from there? Sounds like a pulley is siezing to me. You'd have to pull the belts and try turning them all by hand. I may have a similar issue on my car. I'm in ohio too. This weather is simply tough on cars.
2018 Nissan Pathfinder SL
Well Maroon Sentra as lots of idler experience so listen to him.
As for water pumps, personally i have had them weep and leak but never made any noise.
I don't think its the chain as the noise can be intermittent when it first starts up. I have no leaks out of the water pump so that's a good thing. When occasionally when the noise stops, I can hear a little bit of a squeal. Maybe the pulley locking up and the belt slipping on it? I did notice one of the pulleys (didn't note which one) had a shiny surface on the inside, so this may be it. I have seen some posts about pulling the tire and fender well to get better access to the components. Hopefully nothing catastrophic happens untill I get to it this weekend. Thanks for the suggestions. Will let you know how it goes.
Pull the passenger side wheel off, then the small plastic guard. Leave fender intact. Shiny pullies can be a sign but not always. I am assuming the shiny pulley is the idler pulley? Should have a flat surface and not ribbed. That one is actually common to be shiny. Wouldn't hurt to pull the belts, and turn all of them by hand. You might not find it until it actually goes bad. Check the alternator too.
When you turn on the defrost most cars turn on the A/C compressor if the temp is over a certain value, like 39 Degrees. I Don't know what the Nissan temp is, but i am sure its meant to turn on, assuming the A/C is working anyway !!!
First, start the car and turn the ac on. Check to see if you can feel or hear it click.
Second, turn the ac on and off and watch the ac pully, when it is off it will free wheel and when it is on it will catch.
It might help to have someone hit the switch in the car while you watch the pully.
I'm sure there is a better way to do this but this is how I would check it.
I was talking about shutting it off so it doesn't kick on.
Discussion Starter · #17 ·
My Sentra doesn't do this but my wife's Chrysler TNC and my daughter's Accord does do this. When you turn on the defrost the AC kicks on. I hate that. Still haven't had a chance to look at the pulleys, but will let you know what I find.
he edited / removed his comments in the post....
I have done that before as well, in my case answered without reading all the thread !!
1 - 20 of 24 Posts
