I was wondering if anyone has had experience replacing a washer pum on a 96 Pathfinder? I purchased what I was told was an OEM part but quickly realized two problems. 1. There are two pumps and neither appears to be labled front or rear and 2. The original pumps have two hoses coming from them and the replacment only has one.
I would really appreciate any info as I am stuck.
Thankyou,
Manintrees
Thankyou,
Manintrees
I think they gave you the wrong pump. The replacement should be almost exactly the same.
If you're not sure which is for which, have someone turn the washer on and you can listen for the noise of the pump. But, you should be able to realize which pump is for where by following the lines.
