B13 GA16DET
so i installed the fuel pump today ( walbro 255HP ) in my b13 and before i turned on the ignition and blew myself up, i needed to ask a couple of questions. obviously the fuel pump goes inside the tank ( being thats where the stock one was ) am i correct.
the next thing i had to cut two wires and attach a harness that came with the pump. will dat send a spark and blow it up? the wires are covered in plastic wire crimps or whatever its called thats it.
the pump it came with a rubber foam to wrap around the actual pump. will the fuel eat up the rubber or break it down? i left it in the tank for a minute to look for any signsof damage .no signs of damage.
can any1 help me out im sure a lot of you guys on the forum have installed this pump. thanks guys
