My car's cam chain jumped a few teeth, which bent the intake valve.
i had the head redone with new valves and shims. put a new genuine cam chain set on.
Checked timing on timing marks, which chain mask applicable on marks.
Started engine and engine wont run pass 2700rpm, and sounds bad, error code appeared P1136
changed vvti Controller, checked wiring and all is good. Still get P1136 code, checked vvt gear and all seems the same as other bank.
Any help or ideas to try resolve this pls?
