I’m changing the passenger side valve cover gasket on my 97 Pathfinder. I got back an original Nissan gasket but I’m using the Felpro grommets.
I know the original setup has a rubber grommet inside a metal washer. Can the Felpro grommets work with the metal washers from Nissan?
Or do I simply use the felpro grommets by themselves? Because I noticed the felpro grommets have one side thats metal and the other side is rubber. If so which side should I put facing up or down.
Thanks
Sup Mod keeping the peace
The metal side should be facing up otherwise the bolt head will dig into the rubber possibly ripping it. Who needs another oil leak!
