Agree. What weight did you use. Also, If you had any prior oil leaks, you need to fix prior to using any fully synthetic oil. Synthetics are much thinner than conventional.Synthetic motor oil is superior to dyno oil so it should provide smoother operation. Just make sure you're using the proper weight oil, like 5W30 or 10W30.
