1 - 19 of 19 Posts
I don't know if anyone has tried this yet but I put an unorthodox racing 91-94 SE-R water pump pulley on my 97 1.6 tonight and it works awesome. Only modification I had to do was get a longer belt by about 1/2". Gonna try the se-r alternator pulley next week and see how that goes.
William
Was easy, took me about an hour just because I had to get someone to run me to get the belt :) The pulley bolted right to the water pump without a problem.
What about the underdrive pulley, can a UR underdrive pulley from GA16 be fitted onto an SE-R, are these switchable too? Im sure that I should get the SE-R pulleys but I cant afford them and already have a pulley for my GA16 that I might sell.
se-r and 1.6 crankshaft diameters are probably different. that's a pretty good news I guess that waterpump pulley fit though. I think you should email UR and sentra.net staff so they could research it and maybe dyno... waterpump for se-r is larger then stock to prevent waterpump cavitation at high rpms... whether that is beneficial for GA16 would be interesting to find out
Yeah I don't believe the 1.6L pulley will fit the 2.0 by looking at it.
I took the car out last night and really got on her, it never got above normal temperature, and I can feel a difference, it revs a lot smoother and pickup is a lot better. I can't wait to try the alternator.
DNE's VZR Conversion
the 1.6 L motor cannot fit the SE-R Crank Pulley.. the water pump and everything else is fine. ( im guessing)
I'm gonna have to follow this, if it works without downfall, I might do it too. Why didn't someone think of this before?:eek: :D
Nissan Freak
how much u want for the pulley??
also from wha ti read while back there was no gains with other pullies on a ga motor that is why ur only came out with one
Discussion Starter · #17 ·
Bickmade / Xtreme: I have a bunch of the pullies coming in, they should be here today. I want to double check part #'s and i'll post up details / prices today.
Andre: No problems, she runs like a champ.
1 - 19 of 19 Posts
