Status
Not open for further replies.
Yea, I'm a freak..
TSB's 2002+
Below are a listing of current Document Summaries, TSB's and Misc info. A huge thanks to Hardcore and Jayman for their help in getting this info to you guys.
Document Summary_0
Ambient Temp not reading correctly.
Document Summary_1
MIL on, wont accelerate past 20mph
Document Summary_2
Open Fuse for rear tail lights
Document Summary_3
FM Radio static
Document Summary_4
Cruise Control inoperable
Document Summary_5
Hiss noice while HVAC is operating
Document Summary_6
Grease streak on windows
Document Summary_7
Cargo Net hook missing
Document Summary_8
Auto tranni leaks
Document Summary_9
Unique Flywheel bolts
Document Summary_10
Reverse Lamp goes dim
Document Summary_11
Noise from radio w/ volume at 0
Document Summary_12
Fuel gage/sending unit replacement
Document Summary_13
Instrument cluster Identification
Document Summary_14
Auto tranni wont shift past 1st gear
Document Summary_15
Parking Break Adjustment
Document Summary_16
Engine seems to run hot (QR25)
Document Summary_17
Drivers side windows/door lock
Document Summary_18
Knocking noise from engine (QR25)
Document Summary_19
CAN communications diagnostics
Document Summary_20
2.5L Windshield washers "INOP"
Document Summary_21
A/T Shift lock solenoid operation
Document Summary_22
No turn signals or 4 way flashers
Document Summary_23
Engine Overheat
Document Summary_24
Cooling fans are on all the time
Document Summary_25
2.5 Lack of power
Document Summary_26
Will not start, battery drained
Document Summary_27
Buzz noise at 2500-2700rpm , Moderate Load
Yea, I'm a freak..
Discussion Starter #4
Manual Transmission Oil
2001-2004 ALL NISSAN: MANUAL TRANSMISSION OIL
REQUIRED FOR WARRANTY REPAIRS
Applied vehicles: 2001-2003 All Models Equipped with Manual Transmission
2004 Maxima (A34) - All Models Equipped with Manual Transmission
Service Information
If an Applied Vehicle eqiupped with Manual Transmission needs servicing for warranty repairs, Nissan Manual Transmission Fluid (MTF) HQ Multi 75W-85 oil
(P/N 999MP-MTF00P) is required.
Important Note: Nissan MTF HQ Multi 75W-85 oil must be used when performing manual transmission repairs paid by Nissan. These include warranty, service contact, or goodwill repairs. Nissan will not reimburse dealers for manual transmission repairs when Nissan MTF HQ Multi 75W-85 oil is not used.
If a manual transmission requires the oil be drained for maintenance or repair (customer pay work), 75W-85 oil is required as the service fill fluid.
Nissan recommends use of MTF HQ Multi 75W-85 oil, which optimizes shift quality, for customer pay use as well.
Status
