1 - 8 of 8 Posts
Hi Guys, i`m from Argentina and new in this forum, i have read a lot a useful things here and i do use the search button a lot ;)
My 92 NX model is HAYALVFB13EWA so that means it`s a GA16DE with EFI (among other things) and i`m preety sure it has VTC as well
What i can`t figure out it`s the actual HP for this engine, some say 105hp, others 110 and i`ve read somewhere even 120hp but i think this is for newer models only. In the service manual it`s listed as "Except Europe", can someone give me a stright answer?
Thanks!!
thanks both for the replies, now:
wikipedia.com. you have us spec, japan spec, europe, exc. I believe the american ga16de is 110. look around google and this site, you can find anything.
i did check wikipedia but it´s not very clear, that´s why i asked here, i´m sure that mine it´s not europe specs because that´s what the service manual says so it should be 110hp (usa specs), but it seems that there´s no easy way to confirm it
115hp @6400 rpm
96lb-ft @4000 rpm
there were 115hp ga16de in 1992? :confused:
Block Rockin Beats
Most of the data I've seen says B13 US-spec GA16s are 110HP/108Lb-ft. B14 GA16s make 115HP, mostly because of the better cams.
Apprentice Technician
you're right, i'm wrong. forgot the first gen DE had more bottom end, and the 2nd gen had more top end. i posted 2nd gen specs.
personally, i'd take a 91-94 ga16de if thats the case. 12lb-ft vs. 5hp. if it's a cam issue, the 2nd gen cams will slide in the first gen. just go grab some from a junkyard and get 'em reground, or find some JWT's (they make em don't they? or used to).
1 - 8 of 8 Posts
