One of the first things to do is perform an ECU code readout with a portable scan tool to see if any fault codes are set. The tool can be purchased at most auto parts stores or online at Amazon.com. Post the actual codes here on the forum so that we may be able to help you further. If there is one or more fault codes set, they can help point to the malfunction. If you have a copy of the FSM for your vehicle, the code readout procedure is described there along with a listing of codes. You can download a copy of the FSM from this web site: Nissan Hardbody D21 Truck Service Repair Manuals. The section EC.PDF is the one you need to read.
Several things that could cause misfires:
- Is the misfire occurring on any particular cylinder? What brand of spark plugs are you using? You should be using OEM NGK plugs; other brands such as Champion or Bosch many times cause driveability problems in Nissan engines.
- The cam position sensor may be marginal; it's located inside the ignition distributor.
- Incorrect fuel pressure. Tee-in a temporary fuel pressure gauge between the fuel feed hose and the fuel rail. The readings at idle should be as follows:
- with vacuum hose connected to the fuel pressure regulator: 34 psi
- with vacuum hose disconnected from the fuel pressure regulator: 43 psi
- There may be a major intake system vacuum leak. To check the intake system for a vacuum leak, attach a vacuum gauge to a full vacuum source. With the engine fully warmed up, the reading at idle should be 18 - 20 InHg. At 3,000 RPM, it should be 21 InHg. If readings are under 18 InHg, check the intake manifold nuts to make sure they are tight. The gasket may have failed; spray a water mist at the gasket to see if the gauge reading changes. Also check the intake plenum bellows at the throttle valve and at the MAF for cracks or loose clamps.
- Dirty fuel injector(s). Run some good injection cleaner, like BG products 44K, through the system; give the cleaner about a week or two to do it's job.
