I've talked to a few people and some say use Pulsar 5 speed transmission for a CA18DET swap, while others say Stanza 5 speed. Which one would be best for this?
why not just get the tranny for a ca18det when you order the engine... you can use a 5 speed tranny from a pulsar if its a pulsar with the ca18de in it.... I dont know about the stanza i would try and order the tranny with the engine ..
The only way you're going to get a FWD CA18DET is if you get the 87-88 model that has the intake that crosses the valve cover. The 89-91 models (to my knowledge) all have 4wd trannies. You cannot use the AWD tranny's flywheel with the U.S. spec tranny or at least I wouldn't try. The 1986-89 stanzas tranny would work Good Luck!!!!!!
Nissan Forums is the go to place to talk about your favorite Nissan model, including the Rogue, Maxima, Altima and even sports cars like the 370Z and 200SX.
