So Im stuck now swapping my girlfriends trans in her 05 Maxima and was wondering a few things. First is there a specific fluid people have found that runs better in these or just the oem stuff? Secondly I know the filter is in the trans and I need to disassemble it to replace it, the replacement trans has 110k on it, so Im wondering is it worth it to replace the filter while I have the trans on the bench? Third and last is there anything else people normally replace or change on these trans while there are out before I put it in? Main concern is hers failed at 150k so Im hoping to get more then 40k miles out of this next one.... Thanks in advance!
Sup Mod keeping the peace
If you plan to disassemble the tranny, take a look at the strainer (filter) for any debris; while in there find the three magnets that are on the oil reservoir plate; clean them up. As far as using a favorite ATF, the OEM oil is as good as any. You can look into the Mobil1 Synthetic ATF.
NF Mod/Nissan Master Tech
There is no filter, only a screen mesh, so no need to replace it. I would replace the diff seals, at least, and it wouldn't be a bad idea to replace the front seal where the torque converter is and to check the engine rear main crank seal. I use Valvoline Maxlife Full-synthetic ATF in every automatic transmission I own. It's compatible with NissanMatic "D," "S," "J" and "K." Also, it's only costs $18/gallon jug at Walmart, so it's a lot less expensive than NissanMatic. Castrol Transmax Import Multi-Vehicle ATF is another good choice.
