Hi there,
I have a 91 Sentra with an auto transmission. I want to know if anyone with the same car had experienced what I do. Sometimes when it shifts it is quite noticeable for example if it's shifting from 2nd to third it feels like as if something pulls the car back slightly. And another thing I've noticed sometimes when I press the gas pedal it is so stiff almost like someone wedged a brick under it lol and then moments later it's normal. I hope nothing is wrong, just wanted to know if anyone else has experienced a similar thing. Thanks for any input.
Eric
maybe you have a brake caliper sticking causing it to feel as if its braking between shifts?
have you tried cleaning your throttle plate or maybe lubing your cable?
you could have a bad place in the cable causing this to happen.
