1 - 7 of 7 Posts
Going to change my transmission oil in a manual 98 N15 pulsar, couldn't find any gl-4 80-90 oil at repco or supercheap shops, closest i've found is Fuschs titan rx80. It's a gl-4 oil, but it's SAE-80W not 80-90 which is recommended.
Will using sae-80 be fine, or should I endeavor to find some mtl-90(not too keen on the price $100+ vs $50).
Ultimately if the rx80 isn't going to damage the geabox, and will preform well I'd like to use it. however if it's not good then i'll spend more to get to correct oil.
from the fusch website:
"TITAN Gear RX 80
A transmission lubricant suitable for use in most manual transmissions where improved low temperature gear shift is required. Can be used in the manual transmission of most manufacturers, including Mitsubishi, Nissan, Ford, GMH, Toyota and Mazda. Suitable for use in most front wheel drive vehicles.
Specifications:
SAE 80W API GL-3/GL-4"
2018 Nissan Pathfinder SL
where are you located ?
How hot does it get there in the summer ?
did you check your owners manual or the FSM ?
I'm in wellington New Zealand. It doesnt get too hot here, usually 17-25 degrees C in the summer max 30C; 9-18C in the winter.
Owners manual is 80w-90 gl4, which I couldn't find except redline mtl-90, guy at the shop thought it "should be ok".. but now I'm not sure. there isn't as much info on the net as i thought there would be in regard to this oil; possibly that suggests not many people use it
here is the Documentation from the FSM
So GL4 SAE 80W is fine if you are under 30C
BTW I had 4 litre of Fusch syn engine Oil I finally used, I don't think they sell it here in the USA, It was a Gift at the Singapore motor show when i signed up for the local Auto rag.
:D In she goes! Will see how it works later today, don't think it's been changed before or in awhile at least so will be interesting to see the difference. Thanks for your help, really appreciated.
1 - 7 of 7 Posts
