93 Nx where the past month occasionally sounds like its grinding the gears. The clutch does its job. It will only make the grinding sound (once shifted into gear (2-5) when I'm releasing the clutch. It goes into every gear fine. It may do it a couple times in a row or a day not a all. Tends to do it more downshifting between 2-4 gear and when its cold. Fluid level fine, I was thinking either synchronizers or a problem with the clutch releasing. Any info would help, Thanks.
2018 Nissan Pathfinder SL
I used MT-90 and it helped both my GA16 andSR20 manual boxes
