Hey guys, I have some fluid sweating from two lower bolts at the middle of transmission. Doesn’t drip yet just sweats a bit.
You've got an internal seal that's starting to wear a bit or your transfer case is overfull with oil.Sorry I meant the weeping is from transfer case.
Ive never changed the fluid on that as far as I can recall. The fluid is a bit brown.You've got an internal seal that's starting to wear a bit or your transfer case is overfull with oil.
If your car is a 2012 or older, then Dexron II is used and the color is red for new fluid. If the fluid is a bit brown, that's OK; if it's dark brown or black and has a burnt smell, then there may be internal damage. 2013 and newer cars use a Differential Oil Hypoid Super GL-5 80W-90 or API GL-5 Viscosity SAE 80W-90.Ive never changed the fluid on that as far as I can recall. The fluid is a bit brown.
Should I worry about this, it doesn't drip as of yet. Dont even know how long its been like that, I just happened to notice when checking underneath the vehicle today.
Also, should I do a fluid change on that? I know the service manual doesn't have a recommendation.
Thanks Rogoman.If your car is a 2012 or older, then Dexron II is used and the color is red for new fluid. If the fluid is a bit brown, that's OK; if it's dark brown or black and has a burnt smell, then there may be internal damage. 2013 and newer cars use a Differential Oil Hypoid Super GL-5 80W-90 or API GL-5 Viscosity SAE 80W-90.
It would be good to replace the fluid. The FSM states that if towing a trailer, or using a car-top carrier, or driving on rough or muddy roads, change (not just inspect) oil at every 30,000 miles (48,000 km) or 24 months.
Castrol Transmax High Mileage ATF would be OK to use. However I would hold-off using the Lucas Transmission Fix if the Castrol ATF stops the leak. The fluid capacity is 2.2L (2-3/8 qt). There's a fill plug on the side; keep pouring the ATF in until it starts coming out on it's own; now you know it's full. The car needs to be level when you're filling the case, so don't jack the car up in the front; if you do, the fluid level will be incorrect.Thanks Rogoman.
Would it be okay to use Castrol Transmax High Mileage ATF in my transfer case because of the seal conditioners in this fluid. And some Lucas Transmission Fix to help with seals?
I’ve read of people changing the fluid and not being able to get back in the same amount? I know it takes 2 quarts and change.
Is this something I can do in my driveway without issues?
No, not coming from there. It’s the transfer case that it’s coming from directly.That's where the transmission and transfer case bolt together. It's more likely the rear seal of the transmission as opposed to the front seal of the transfer case, but you really don't know unless you dye test the transmission and let it go for a little while before checking with a UV light, or, by removing the transfer case.
Thanks smj999smj.Well, in that case, the best you can do without removing the transfer case and separating the case to reseal it is put a wrench on the bolts and make sure they are tight, clean the residual oil off with some brake cleaner and let it dry and then smear some gray RTV sealant along the seam where it's leaking...then cross your fingers!
When the tranny is cold and not running, a lot of the fluid has drained down into the pan, so it'll show a higher level on the dip stick. The proper way to measure the fluid level is to fully warm up the tranny and while the engine is idling, check the level.Thanks smj999smj.
One more thing, in regards to the transmission fluid, when I changed it a few months ago I drained and refilled then cycled through the gears several times and tapped up.
I was checking my fluids just now and when it’s cold without even starting the fluid is up to the hot line.
Is that just because I didn’t cycle through gears? I know the best way is to to be warm when checking fluids but I was curious about this case.
Did it overfill?
I think you were right on the leak between the transmission and transfer case. I have changed the fluid in transfer case and applied the RTV sealant to the seam where it appeared to sweat. I’m still finding fluid around the area and a little ahead of it towards the transmission and transfer case contact point where there’s two weep holes. I’m not sure why it was located more towards those two bolts in picture. Maybe it was running back?That's where the transmission and transfer case bolt together. It's more likely the rear seal of the transmission as opposed to the front seal of the transfer case, but you really don't know unless you dye test the transmission and let it go for a little while before checking with a UV light, or, by removing the transfer case.
