I have a 91 240 and we just added an sr20 swap. the transmission worked fine for about two weeks and then all of a sudden it wont go into any gear when the engine is started. but when the engine is off it will go into gear. the trans fluid is ok i just checked it. the slave cylinder looks like its working but im just lost please help.
- Check the clutch pedal free play; if too much, the clutch doesn't fully disengage.
- There may be air in the hydraulic system. You may need to bleed it.
