1 - 8 of 8 Posts
Ok so over the last 2 months I have noticed that when I put the truck into reverse or make a sudden turn I heard a loud rubbing/ vibration noise. It seems to be coming from the tranny mount area. I looked under there and It looks pretty worn. The engine mounts look pretty good not as worn or gooey.
Online i found this
2002 NISSAN FRONTIER Transmission Mount
everywhere i go they say the 4x4 mounts are the same as the 2WD mounts (i have a 5 speed. Is this the mount cuz everywhere else has it for like 60 bucks this looks like a great deal.
also it looks pretty easy to change, just loosen the bolts, jack the tranny up a bit and pull it out. Is this how it goes? I am broke so I want to do this myself, dealer wants like 300 to do it, anyone done this before? thanks for your help
Online i found this
FWIW, it's the same image that shows up on the Advance Auto Website (a local chain around here) for $60-ish. Too bad you can't find a poly mount (from someone like Energy Suspensions), it'd hold up a lot better than rubber.
I've not had to change the mount on my truck, but based on what I remember from changing one on another RWD vechile, your procedure sounds correct.
Have you checked the U-joints and carrier bearing as a source of the noise?
That's how it's done. Do it yourself and save the dealer cost.
so when i went to go get my oil changed I had them inspect the mounts (body, motor and tranny), carrier bearings and basically any movable joints and items close to rubbing. They found nothing. I can now hear/feel the sound when i turn, its not loud but i can hear and feel it. I also checked my bushings, tirerod ends and everything looks ok. Anyone have any ideas. I really do not want to take it to nissan I just do not have the $$$ to do it.
Where do you feel it?
Seat of the pants -- driveline component or body mount problem maybe.
Through the steering wheel -- steering component or front suspension or front brakes maybe.
1 - 8 of 8 Posts
