1 - 9 of 9 Posts
Do anyone of you know if I asbsolutly have to bleed my gas line in order to replace my gas filter ?
my battery is kinda low and if I bleed the gasline, I'm pretty sure I wont have enough juice to crank the starter as many time as I will need in order pump back gas all the way to the injectors...
· CA18DET Wizard
No need to bleed yor gas line. Just catch some of the gas from the old filter in a cup and when you're ready to restart the car, pour a little gas down the carby's throat 1st and it should fire right up.
· Still moderating..sorta
I think that dropping gas down the TB will probably flood the engine but I'm not sure.
Well I'll be damned :)
When I changed my fuel filter I never disconnected the fuse or anything like that, just took off the hose with my finger clamping it shut and I never dripped a drop of gas and then I had someone else bolt in the new filter and all done!
1 - 9 of 9 Posts
