R
RED92SE-R
·Guest
Ok, I have a nearly perfect 92 SE-R...I've had it for 3 years, it's only been worked on at Nissan dealerships, I've never had any problems with it, always maintained it the best possible way.
However, one little problem is driving me insane...nothing major, it's just a hassle. Here's what happens:
1) The fuse that controls the clock, station presets on the radio (not the radio operation itself), interior light and trunk light keeps blowing every time I put it in. This is the fourth fuse from the bottom on the left side (10 Amp). The label says "room lamp".
2) When I start the engine, the radio comes on and resets at 1:00. The radio comes on, but you have to set the stations every time. This happens when the fuse is blown already - so it's understandable.
3) When the engine is off, I can put the fuse in....but when I open the door, it blows. Basically, that points to the indoor light, triggered by an opened door..and here's why...
4) When the engine is running, even with the blown fuse, if I pull the light bulb out from the ceiling, the radio stops working and the clock is gone!
5) With the engine running and a fuse in (with doors closed because that's the only time it will not blow), when I switch the indoor light to "ON" or "OFF", the fuse blows. When it's in the middle, it's fine.
6) I pulled the light assembly out and those wires seem ok.
7) I looked under the dash and found no visible loose wires
I just replaced the radio (needed to be done) and I'm positive I did it right, the problem existed before and after.
Any help would be appreciated...I'm willing to do anything short of removing the entire dash.
Thanks in advance!
Thanks in advance!
